B17 & B16
Re: B17 & B16
Re: B17 & B16
You should be able to, Honda has virtually the same wrist pin, rod big-end space, press-fit, and compression height dimensions for all b-series. CTR is about the only exception.
The B17 is the same block dimensions as the B16, only it has a longer stroke for more displacement. The rods must be shorter, to make up for that space. Honestly I'd suggest you find a B17 crank and use the rods you have. That will get you more torque, which will really help that b16.
Re: B17 & B16
its all good we all have a little brain fart every now and then
x2. also itll be easier to find a B17a crank & sell your B16a crank than it will be to sell your B17a rods.
Re: B17 & B16
Re: B17 & B16
okay i try putting everything in but for some reason the Pistons are hitting the squirters inside the block and i have idea what to do now lol
Re: B17 & B16
okay i dont wanna go through the trouble of not making nothing fit, so i was wondering if i still could use my B16 rods for my B16 block/crank with B17 Pistons and which wrist pins do i use for my new set up.
Re: B17 & B16
funny if you check out the nsx-r issue of honda tuning theres a green b16a powered turbo hatch...b17 crank....and hes pushin 650....so it should work that way
Re: B17 & B16
yeah but i wasnt trying to go out and find me a b17 crank lol, so ima use my B16 crank and use my B16 rods, but i was wondering if i could still use my B17 pistons on it?
Re: B17 & B16
Yes you can use the pistons from the B17 in your B16. I actually have GSR C1 pistons in my B17. If you do go with your B16 rods, I'll snag them B17 ones from you. Crower I would assume, seeing as they are the only company that makes them for the B17.
Re: B17 & B16
yeah dude, id be totally down to sell them to you, i just bought some Pauter rods, the B17 ones are Crower
