OBD2 distributor on OBD0->OBD1 conversion?
Old 08-10-2007, 01:23 PM
Wheelman-CZ's Avatar
Default OBD2 distributor on OBD0->OBD1 conversion?
Hello!
I am going to rebuild my OBD0 B16 to the OBD1, I know I need diferent distributor, I have some TD81U laying at home, can I use this one?
I know if I am rebulding OBD2 to OBD1 I dont need to change the distributor.
Can I do it this way?
Thanks for answers!
Old 08-11-2007, 10:45 AM
Katman's Avatar
Default Re: OBD2 distributor on OBD0->OBD1 conversion? (Wheelman-CZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wheelman-CZ &raquo;</TD></TR><TR><TD CLASS="quote">Hello!
Thanks for answers!</TD></TR></TABLE>
TD81U is a 96-98 DOHC VTEC distributor.
You can use this dizzy and it's compatible with OBD1 ecu's, but you just need to change the wiring around to an OBD2 b-series vtec distributor plug on your engine wire harness side. Simply repin by color matching wires.
As an easy alternative if you're afraid to wire yourself, Rywire sells a mini distributor adaptor which will sold your wiring woes:
http://rywire.com/store/obd0-o...f241f
Old 08-12-2007, 01:53 AM
Default Re: OBD2 distributor on OBD0->OBD1 conversion? (Katman)
I know about the repinig it.
This is great info, thank you a lot!!!!!
ej8_fredi
03-28-2009 11:10 PM
TougeGroceryGettR
11-29-2006 05:36 PM
.M.
05-27-2005 08:18 PM
specie
06-14-2004 06:32 PM
Quick Reply: OBD2 distributor on OBD0->OBD1 conversion?
