resistor box elimination
Ok so two of my injector plugs are giving me problems and I narrowed it down to wiring so I was wondering if there was a way to eliminate the resistor box and I just wanna run wires from my problem injector plugs to the ecu. Can I do that without making more problems for myself
Re: resistor box elimination
Hear you go hope this helps. Check all your wiring from this link. I used it to learn how to do dpfi to mpfi swap about a year and a half ago its pretty simple and easy to follow.....
http://hondaswap.com/swap-articles/d...writeup-49557/
http://www.youtube.com/watch?v=kUTG_0cQ6lc
That's what I did and it's the cleanest way to do it.
First get some OBD1 injectors and then do what this guy does in the link:
My car is a 90 crx si with a b18b1 obd1 conversion with pr4 ecu. I wanna check the wiring from the resistor box to the obd1 conversion but can't figure out what runs where does anyone have a diagram for a obd1 conversion before I go into removing the resistor I want to check over the conversion harness car was bought already done I just wanna double check it
Honda_Tengoku
04-11-2004 03:00 PM
boostin b16
03-02-2003 03:03 PM
90_Civic_Hatch
06-13-2002 09:00 AM
