Which O2 sensor for PR3 with two O2 sensors??
Okay, when I ordered the o2 sensors, I got four wire type with the wrong connector - can these be modified or which USDM equivalent to order??
thanks, all
thanks, all
im assuming you have the preobd pr3 ecu.
You could use them and convert to 4 wire, but they cost so much.
I would return them and pay 1/2 as much for 1 wire o2 sensors.
yes, the obd0 PR3 the harness looked like one wire and so the sensor had 4 and that kind of messed me up
doed it matter which sensor to use with just the one wire?? which one to order
when i replaced the o2 sensors in my car i bought 1 '90 integra o2 sensor (same connector as the white plug o2 sensor) and 1 universal one wire o2 sensor for the green connector.
are these shrouded wires from the engine harness to the o2 sensor(s)? i looked at a couple of harnesses and when you look at the wires they are insulated and then there is a thin layer of silver wire underneath an outer insulation.....
mugenhatch92
Aug 21, 2004 09:25 AM
slwazgsr
Oct 17, 2002 06:53 PM
