trying to hook up my sve 3 bar. all the sites i find with any info have the oe map sensor wires way different than mine and my helms is a piece of crap
my colors are white, blue, yel/grn. wtf...and i dont have a multimeter to test either. i just need to know what wires are for power, sensor, ground so i can splice into my pigtail
up
Unfortunately some of them are different colors, did you check to make sure it's not the TPS sensor ?
Get a multimeter or borrow one to know for sure.
what kind of car do you have ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">Unfortunately some of them are different colors, did you check to make sure it's not the TPS sensor ?
what kind of car do you have ?</TD></TR></TABLE>
its a 92 dx civic hatch. the map was originally firewall mounted, so the map plug comes out of its own harness and out out of the main engine harness like the tps. im sure its map because ive been running it fine for 500 miles. i did go out and buy a multimeter. im looking ground, 2.8v for signal and 5v for power right?
in case anyone searrches this in the future - blue/grn was the ground, white was the signal and yel/grn was the 5v. just took the car out for a spin and it worked finee, boosted no prob and no map codes
