JDM Cluster in 92 EG..DX
Just installed it tonight and can get everything to work but my tach. I have a green wire on the back that does not seem to have a place to go is this related to tach? My car didnt hav Tach originally so i figured the yellow 3 wire plug would be my tach wires, but any help would be great
Re: (JCL)
did yours have a green wire? it was seperated from the 3 plugs and was sodered to the back of the board on the heat/fuel side of the cluster. If so what wire do i hook it too on my harness? Or is there a wire that is hiding?
Re: (crxcel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcel »</TD></TR><TR><TD CLASS="quote">did yours have a green wire? it was seperated from the 3 plugs and was sodered to the back of the board on the heat/fuel side of the cluster. If so what wire do i hook it too on my harness? Or is there a wire that is hiding?</TD></TR></TABLE>
It should be a direct, nothing "should" be hiding. Could it be possible the tach is busted?
Did you just buy this?
Re: JDM Cluster in 92 EG..DX (crxcel)
everything should already be on the harness. just a plug - n - play. if the tach is not working, then it's the tach, not the wiring.
Re: JDM Cluster in 92 EG..DX (93egryda)
I have all 3 plugs plugged in, but there is anotyher green wire all by itself that looks factory sodered to the back of the cluster..I will takes some pics and put them up on monday. And yes i just bought the cluster. Any fuses that are for the Tach?. All the other lights/guages work fine
joecivic93
01-06-2004 10:07 PM
