NEED Help!!! crvtec attemp going wrong!!
Old May 14, 2002 | 07:25 AM
hybridmoose's Avatar
Default NEED Help!!! crvtec attemp going wrong!!
Ok heres the deal. Me and my boy are building up my crvtec engine and we cant get the damn crank pulley bolt to com off!!! Ive broken 2 sockets and bent the hell out of my breaker bar. Can anyone give me an idea of what to do to get this infernal thing off???
Thanks in advance.......
Old May 14, 2002 | 09:52 AM
EE_Chris's Avatar
Default Re: NEED Help!!! crvtec attemp going wrong!! (hybridmoose)
Well that was a mis-leading title
This topic has been covered before....search didn't turn up anything?
Anyway, to answer: Using a socket, breaker bar + 4ft cheater pipe will/should do it. You can try some PB Blaster first, let it soak, hit it with a hammer (to try and break it loose a little) and then get on it with the 4ft'er.
But personally, my impact took care of it....but sometimes the impact is not the end all be all to getting that thing unstuck, as many a board member will attest to, thats why I suggested the 4ft'er first.
Good luck.
Old May 14, 2002 | 11:36 AM
JD_B18CDX's Avatar
Default Re: NEED Help!!! crvtec attemp going wrong!! (EE_Chris)
If he's broken sockets that means the crank bolt is really really really stuck.
I am assuming you found a way to keep the crank from turning.
Anyway, what you need is a high carbon socket. The ones being used by impact wrenches should be good.
Also, get a braker bar with a lifetime warranty. Its only a few bucks more, plus when it breaks, you get a new one.
Old May 14, 2002 | 11:37 AM
dbman96's Avatar
New User
Sounds like someone's using 3/8" or thin-wall sockets. Get an impact-rated socket set (Harbor Freight sells them cheap) and use a 1/2" breaker bar with a good length of cheater pipe over it. Or get an impact wrench.
Old May 14, 2002 | 01:06 PM
95GS-R's Avatar
Default Re: NEED Help!!! crvtec attemp going wrong!! (dbman96)
I was reading a post like this about a guy with a CRX that was trying to get his crank pulley off. He said he used a cheater bar and jumped on it until the bottoms of his feet hurt, and it finally gave.
A guy a know tried with his Civic EX and gave up in the end and took it to the dealership. I imagine they gave it to him raw.
Old May 14, 2002 | 01:39 PM
Kamin's Avatar
Default Re: NEED Help!!! crvtec attemp going wrong!! (95GS-R)
yea go to like sears and get a small set of impact sockets (they always come in handy) a new wrench while your at it. (lifetime warranties rule)
go to ace and get a 4ft long pipe with an opening big enough for the socket wrench
then go to town on the pulley
if this STILL dosent work, get a friend with a GOOD impact wrench.
you might want to give it a liberal dousing of wd40 or triflo (if you can get it) and give it some time to let it work
good luck
shutta
Nov 13, 2005 02:34 PM
uncald4
19
May 15, 2005 06:31 AM
luti
28
Jan 9, 2005 01:05 PM
slwburn
Apr 3, 2004 04:15 PM
hatchdrvr
Feb 13, 2003 04:00 PM
