NEED HELP WITH A MOUNT QUESTION!!
Old 08-09-2009, 10:26 AM
ChinitodeNJ's Avatar
Default NEED HELP WITH A MOUNT QUESTION!!
So I bought a 96 ex shell and later bought a 98 GSR to swap in it. So as I tryed to make sure I had the correct mounts I noticed the mount on the driver side did not fit to the pins. So at first I thought I had the wrong mount but then later I realized it seemed like someone changed the piece with the pins on it. So my question is where is the piece with the pins from and what mount fits on it?
Old 08-09-2009, 10:52 AM
Default Re: NEED HELP WITH A MOUNT QUESTION!!
bumpp
Old 08-09-2009, 11:37 AM
bummpp
Old 08-09-2009, 12:26 PM
Seagull Management
94EG8's Avatar
mount and bracket need to come from a '99 - '00 Civic Si.
Old 08-09-2009, 12:36 PM
that is the mount and bracket from a 99-00 si.....
Old 08-09-2009, 12:44 PM
Seagull Management
94EG8's Avatar
When I said mount I actually meant the 2 post mount attached to the block itelf.
Master Detailer
98civdx's Avatar
i dont think its from a 99-00 si, its most likely from the integra
Old 08-09-2009, 12:53 PM
ohhh ok my bad thanks
Old 08-09-2009, 12:54 PM
Seagull Management
94EG8's Avatar
Doesn't appear to be from an Integra, they use a 3 post mount, which is why you need the Si mount and bracket in the first place.
Old 08-09-2009, 12:56 PM
Master Detailer
98civdx's Avatar
opps, your correct, thank you for correcting me.
i was thinking of my buddys mount, 2 studs and a bolt.
Old 08-10-2009, 02:11 AM
Seagull Management
94EG8's Avatar
Actually upon closer inspection you may be right. I see a third hole.
Old 08-10-2009, 01:45 PM
Master Detailer
98civdx's Avatar
one way to find out. op is that third hole in front of the 2 studs threaded or have a bolt underneath??
if it is you have a integra mount, not civic.
_kiid
Texas -OK -LA (Sales)
28
08-11-2009 01:29 AM
donkiman
07-18-2005 03:46 PM
lscoupe
04-24-2005 11:15 PM
bretx0r
03-24-2003 03:27 PM
deviant1
10-15-2002 07:00 PM
Quick Reply: NEED HELP WITH A MOUNT QUESTION!!
