motor mount
Old 09-09-2003, 08:07 PM
Ransom's Avatar
Default motor mount
Ok i have a 89 hatch. I had a b18a1 in the car. I threw a rod threw the block and had to get a new motor. The motor that i got is a b18b. I thought that the B18a and the b18b were pretty much the same as far as the blocks are concerned, but when i got the motor the drivers side mount that is attached to the blocks are different. I have the hasport mounts and the mount will fit the b18a, but wont fit the b18b. What should i do?
Old 09-10-2003, 03:56 AM
h22 ef's Avatar
Default Re: motor mount (LudeSH)
hit yourself with a hammer and then switch the brackets
Old 09-10-2003, 05:08 AM
VTECVillain's Avatar
Change the driver's side mount bracket on the B18B1 with the one from your B18A1 and it'll bolt in with no problem.
Old 09-10-2003, 11:36 AM
Ransom's Avatar
thanks for the help that is what i thought.
shaylude01
03-13-2011 03:55 AM
vdubsduncutit
05-02-2010 09:07 AM
GSR-EG-92
10-23-2008 06:14 AM
J.nguyen
08-23-2006 05:15 PM
J.nguyen
08-23-2006 05:15 PM
Quick Reply: motor mount
