LONG Block
Old Oct 12, 2006 | 01:06 PM
Felliph3's Avatar
Default LONG Block
Whats the difference between a small block and long block?
Old Oct 12, 2006 | 01:07 PM
poison's Avatar
Default Re: LONG Block (Felliph3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felliph3 &raquo;</TD></TR><TR><TD CLASS="quote">Whats the difference between a small block and long block?</TD></TR></TABLE>
When people say "small block" they are probably referring to a v8.
Long block usually means it's the oil pan all the way to the valve cover.
Short block usually means just the block itself with no head.
HTH.
Old Oct 12, 2006 | 01:14 PM
Felliph3's Avatar
So whats the difference between the B16 Long block and complete changeover?Will a long block run on its own or will it need aditional parts?thanks
Old Oct 12, 2006 | 01:24 PM
poison's Avatar
Default Re: (Felliph3)
Long block you will need things like exhaust manifold, intake manifold and such.
Complete change over is entire engine, all sensors, ECU, axles and so forth.
Old Oct 12, 2006 | 02:38 PM
TwoRedEGgs's Avatar
Default Re: (poison)
One of the main parts missing in a long block is the transmission. It may also be missin the manifolds both intake and exhaust. People usually specify what the long comes with but not always. A shortblock is missing the entire head and tranny.
Old Oct 13, 2006 | 11:43 AM
Felliph3's Avatar
Default Re: (TwoRedEGgs)
So what do you call a complete engine?
DARS_C_C
Feb 25, 2009 10:09 AM
Integra_RS
Apr 5, 2005 09:36 PM
KarbinFourteen
Mar 3, 2004 09:29 AM
XViEtBoiX
13
Jun 27, 2003 11:08 PM
JediPimpCrx
Mar 25, 2003 06:48 PM
