Tranny leaking oil!!! ARG
Old Apr 17, 2003 | 09:06 AM
DEVIN22CBR's Avatar
Default Tranny leaking oil!!! ARG
Well Ive tried to fix this a few times with the tranny on the car but this looks like its just going to suck .....Its leaking where the outer tranny case bolts the other half which is bolted to the motor. I belive. Its leaving long strips of oil every night : (. So Im guessing I have to pull the entire tranny out ? Correct ? I dont want gears or anything flying around either : p (havent ever had a case aprt i dont know whats gonna happen) but anyone give me the low down and do i just use honda bond ? Thanks
Old Apr 17, 2003 | 09:13 AM
tilt's Avatar
Default Re: Tranny leaking oil!!! ARG (BALL BAG)
are you sure it's tranny fluid? sounds like the main seal the way youve described it.. the rubber ring where the flywheel bolts on to the crank. might be a good time to upgrade your clutch and flywheel. good luck.
Corksil
10
Dec 12, 2009 11:38 AM
Chrislow
Oct 4, 2002 11:37 AM
Mires
Sep 28, 2002 11:06 AM
