Knock Sensor
Knock Sensor
anyone got a graph or a picture or a tutorial on how to wire up the knock sensor to the ecu harness??
i got a check engine light indicating that i don't have one hooked up when i'm roll'in a p72
Re: Knock Sensor (Hapexamendios)
naw i don't...it's jus a stock ecu harness, i was jus gunna make a homemade pin but iunno which slot is the knock sensor slot...
and i got the motor in my EG and a 93 EX engine harness & ECU harness doesn't have an adapter or watever for the knock sensor...so i need a tutorial or something to get it hooked up
Re: Knock Sensor (SpoonxMe)
take a look at the top of this forum.... there is a ecu wiring, and pinning etc thread right there. has everything you need in there. its all i needed when getting mine all set up.
good luck
good luck
Re: Knock Sensor (94hatchling)
shiet...good thinking...lol..i didn't even notice that at the top..but the picture with the ECU inside was the one i needed...saw that on some other thread but couldn't find it...thanx dood!
