jmd b18c1 swap -beginner
Old May 1, 2007 | 04:11 PM
Kriebel89's Avatar
Default jmd b18c1 swap -beginner
Ok, so, I'm looking into getting my first car at the end of this month. I've decided on a civic, which one, im not sure. I've done a lot of research into the engines and what performance mods I want to do; yet, i'm still kind of confused. I had my sights on the 99 ex, only problem, its a d series engine 125 hp (i think), so no swapping to the jmd b18c1. I read that the 92-95 civics were on the b series, so they can be swapped with the jmd b18c1. Ive also read that they are on the d series. I want the coupe more than the hatch, but if i have to get the hatch, i will. So, can I put the b18c1 into a 92-95 civic coupe? Could I put it into the 99ex coupe? (i'm guessing no on the last one).
Thanks in advance for the help
Old May 1, 2007 | 05:10 PM
builthatch's Avatar
MiG-21 superfan
Default Re: jmd b18c1 swap -beginner (Kriebel89)
obd2 jdm gsr would be a very simple swap in your car....BTW, it's JDM, not jmd lol
either car would be ideal for a swap- the older car will be cheaper but it'll most likely have more overall use/mileage and the engine you'll swap will be older (obd1); the later car will be more expensive but the engine you swap into it (obd2) will be newer. it's ideally up to you- whatever car you can afford that'll leave the most money left over for swapping.
http://kosmo.homedns.org/trey/6gen/
if i were you, i'd read on here ALOT and search the net for info to learn about the various swaps and what's required. read as opposed to post.
Modified by builthatch at 12:28 AM 5/2/2007
Stopsign32v
30
Mar 17, 2009 11:04 PM
DCsports06
10
Dec 23, 2005 04:17 PM
ArchAngel Sabastian
Aug 18, 2003 10:47 PM
cash459
May 3, 2003 10:53 PM
XS Speed
16
Feb 4, 2003 10:38 AM
