Ignition problem?
Old Mar 8, 2004 | 12:46 PM
ClayM's Avatar
Default Ignition problem?
Hey guys, i'm trying to sell my dad's 91 LS sedan in order for me to get a new car, yet it has had a reacurring problem that i need to get worked out in order to do so. We've taken in to several shops to get it looked at, and they said it was fixed...but then it would start doing the same thing again. The Problem: Whenever it gets pretty cold outside and you've been driving, and then you go to turn the car off, the car will turn off, but the key will not come out of the ignition. Yet the same problem has also occured when i was at a stop light once (its an auto) and i put it in park, I couldn't get it to come back out of park. So i'm not quite sure if its the transmission or the ignition or what in the hell is going on. Keep in mind this only happens when its cold outside, during the summer it has no problems whatsoever. Any one have any idea what the problem is? Anything would help. Thanks, Clay
Old Mar 8, 2004 | 12:57 PM
stasi's Avatar
Default Re: Ignition problem? (NegroCoupe)
Perhaps it's the shift selector switch? It's a problem I'm still dealing
with myself. The key can't be removed until the car has detected that
you're in park. Replacing the switch is easy. The part can be bought
from a dealer for approximately $50-60.
Old Mar 8, 2004 | 12:58 PM
stasi's Avatar
Default Re: Ignition problem? (stasi)
By the way, this problem is common among 90-93 Integra's.
It's more of an annoying inconvience than a real problen.
Old Mar 8, 2004 | 01:01 PM
ClayM's Avatar
Yea, it usually takes like 5 minutes or so, and then the igntion will release the key. It's just going to suck selling it to someone and them realizing that they cant get the damn key out of the ignition.
Old Mar 8, 2004 | 01:46 PM
stasi's Avatar
Yeah, it may be a little more difficult to sell it. If you don't want to spend
the cash to replace the switch, make sure you explain it to the buyer.
Old Mar 8, 2004 | 01:56 PM
ClayM's Avatar
If it has to do with the switch not detecting the key then why does it stick in park and not go back into drive, it has to be something more complicated than that don't you think?
Old Mar 8, 2004 | 07:02 PM
ClayM's Avatar
bump
Old Mar 9, 2004 | 04:02 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NegroCoupe &raquo;</TD></TR><TR><TD CLASS="quote">If it has to do with the switch not detecting the key then why does it stick in park and not go back into drive, it has to be something more complicated than that don't you think?</TD></TR></TABLE>It sounds like there's a couple of things screwing up, all kinda related to the shifter/brake/key interlocks.
It's not supposed to let you take the key out unless the shifter is in park. So there's a switch on the shift lever that tells the key cylinder that it's ok to release the key. That's screwed up or needs adjustment.
There's also a lock that prevents you from shifting OUT of park, unless you're holding the brake pedal down. So the switch on the brake pedal is screwed up or needs adjustment.
Why don't you see if you can adjust those switches, maybe it's not too hard to just fix it before you sell it...
Old Mar 9, 2004 | 04:08 AM
stasi's Avatar
Default Re: Ignition problem? (JimBlake)
NegroCoupe, the part # for the gear selector switch is: 35700-SK7-A01
You'll need a phillips head screwdriver, 10mm socket, ratchet, extension
and a small flathead screwdriver to install thw new switch. If you need
exact directions to replace it if you decide to do so, let me know.
By your description, I'm 90% sure it's your gear sensor switch.
Old Mar 9, 2004 | 04:20 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stasi &raquo;</TD></TR><TR><TD CLASS="quote">... By your description, I'm 90% sure it's your gear sensor switch.
</TD></TR></TABLE>Yeah, but that doesn't explain why he can't get it out of park. I think his brake switch is ALSO messed up.
Old Mar 9, 2004 | 07:19 AM
krn.racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stasi &raquo;</TD></TR><TR><TD CLASS="quote">By the way, this problem is common among 90-93 Integra's.
It's more of an annoying inconvience than a real problen. </TD></TR></TABLE>
Ya i heard that they had many problems with those. Dont know from experience but i've heard many complaints about that.
Old Mar 9, 2004 | 07:47 PM
ClayM's Avatar
Default Re: Ignition problem? (krn.racer)
If its the brake switch and the sensor switch, can anyone explain why this problem only occurs when its cold outside?... like 45 degrees or less.
Outlaw-Hondaz
Mar 18, 2011 12:24 PM
pootie.teng
Jul 31, 2008 10:37 AM
specie
Nov 25, 2004 02:21 PM
deviant94ex
Jan 2, 2002 05:30 PM
