95 civic dx into 96 civic ex
I have a complete 95 civic hatchback I just recently purchased a 96 civic ex two door shell it came complete except the motor and trans unfortunately my funds are very low and my hatch back is totaled so I want to take my d15b7 and put it into the 96 ex the car already has the step down harness to use the obd1 ecu but what else will I need as far as mounts t brackets can I use anything from my motor or do I have to purchase all new things?? Thank you in advance
Re: 95 civic dx into 96 civic ex
shift linkage and axles are the same.
rear T bracket should be the same. the driverside mount i think is differnt though.
make sure you keep the obd1 conversion and ecu. itl keep you from having 3245345 CELs
Ok so I have everything in the car the only thing I am having a problem with is wiring the obd1 distributor plug onto the harness does anyone have a detailed wiring diagram on how to wire them together
Supahatch
11-15-2005 10:11 AM
intrex
04-14-2004 07:44 PM
Thagreybomber
06-20-2002 07:01 PM
