how hard will it be
Old 07-03-2003, 02:09 PM
fsthonda04's Avatar
Default how hard will it be
ok i have a 1993 civic hatch and i want to swap an h22a in it i have common sence when it comes to working on cars but what i need to know is what ecu can i use? what tranny can i use (5spd of course) and where do i get shift cables and motor mounts?? well i hope you all can help thanks for your time jeremy
Old 07-03-2003, 02:39 PM
junglerunna's Avatar
Default Re: how hard will it be (fsthonda04)
Call up Steve at HMotorsOnline he will hook you up with an engine tranny, ecu, wiring harness, shifter cables
Go to http://www.driveshaftshop.com for axles
Go with either Hasport or HCP engine mount kits.
Old 07-03-2003, 09:08 PM
AudioFuct's Avatar
Default Re: how hard will it be (junglerunna02)
Talk to Newman on the boards about some HCP mounts. Just got mine the other day and they sure do look perty!!! Thanks Newman!
Also, you dont have to use DSS axles. You can use plain ole 93 integra axles if you dont have the extra dough for DSS.
Old 07-04-2003, 10:28 AM
Carnut
Guest
Posts: n/a
i used HCP mounts i like the fact that you dont have to cut off an entire mount and drill in to the chassis
90- 93 accord shifter assembly with cables, any junkyard if you like to crawl throught cars
i used the P13 no problems, didn't wire up egr and get occasional codes no big deal jsut make a block off plate and wire it in
also i used Raxles and they have been holding up good
atarigamer01
08-14-2007 07:14 AM
E36 Guy
08-26-2005 07:02 AM
Mackenzie
25
12-20-2004 04:05 PM
b18civicdx
08-10-2004 08:46 PM
CrOmEdOmEcHaMbEr
08-05-2002 09:20 PM
Quick Reply: how hard will it be
