ls swap?
Old 11-09-2006, 12:08 PM
dylokjai's Avatar
Default ls swap?
what is needed for ls motor into 93 civic hatch cx?
asking because im getting a free 94 ls motor with 100k...
Old 11-09-2006, 12:42 PM
sled's Avatar
Default Re: ls swap? (dylokjai)
do a search....
motor
tranny
ecu
motor harness
axels
mounts
i might be missing something
Old 11-09-2006, 12:46 PM
Former Moderator
B18C5-EH2's Avatar
You will need the following from the 1994-1995 Integra:
Engine
Tranny
Timing side engine mount and bracket
Front side tranny bracket
Rear tranny/engine bracket
A/C mount bracket if you don't plan on running A/C; 1997 CR-V if you want to keep A/C
Axles
Intermediate shaft (bolts to the back of the block and hooks the left axle to the tranny)
Shift linkage
Exhaust manifold
Catalytic convertor
ECU (any 1992-1995 Integra LS P75 will do)
Upper and lower radiator hoses
You'll keep your stock Civic front anti-roll mounts that bolt to the underside of your frame rails, you'll keep your rear engine mount, and you'll keep your upper tranny mount/bracket too. i suggest buying an Energy Suspension brand three piece mount insert kit to stiffen up those front mounts and the rear mount - order them for your Civic, not an Integra
You'll also need a Del Sol VTEC or Integra LS, or Type R throttle cable too.
EDIT
I originally posted this for a guy with a Dx, which has a 4-wire o2 sensor, so for your CX you'll want to get the engine harness for the Integra too, or just wire up the 4 o2 sensor wires, because your Cx only has a 1-wire o2 sensor in it and on its engine harness.
Modified by B18C5-EH2 at 4:57 PM 11/9/2006
D16SiHatch
13
03-29-2008 05:05 PM
2000CivicEK
05-15-2007 01:44 AM
b20vtechatch
04-10-2005 11:46 AM
SpoonFedHatch
02-20-2003 12:03 PM
Scorch7
12-27-2002 02:30 PM
Quick Reply: ls swap?
