Coolant in throttle body?
D16Y7
I know this is probably a noob question, but I just took out my throttle body to clean it and two little hoses attached to it had coolant in them.
why is that?
why is that?
Re: Coolant in throttle body?
Automatic? I believe that model has the Idle Air Control Valve attached to the bottom of the throttle body. Its mainly there for cold weather climates, to warm up the throttle body and keep the throttle body plate from sticking.
The IACV only controls idle speed on engines that are fuel injected. On some cars the throttle body has a water jacket in it to help warm the TB in cold weather. I've seen a cracked TB or bad gasket cause coolant to end up there. O-ring gaskets are notorious for that.
Hope that helps a bit,
CMM
CMM
bmxfelon420
03-20-2010 04:11 PM
hkrichard
04-27-2008 06:03 PM
mini-cRx
03-24-2004 09:18 AM
