h2b need help asap
Old May 3, 2011 | 08:53 PM
Em1L0ver's Avatar
Default h2b need help asap
anyone help me out please any info will help, this is my 1st swap so just bare with me.
i got a 2000 em1/si went h2b
JDM H22A 92-96 and type r tranny qsd kit
the car turns on fine with no problem at all but the car wont rev past 3500 now some of my friends are telling me its my wire harness, ecu, motor im stuck here and i want the car on the road.
i got one pic and video
pic is the intake manifold to see if i did everything right
video is just the engine rev
pic - http://i56.tinypic.com/9k0x9j.jpg
video - http://youtu.be/dS2Vrwq8rBw
Old May 4, 2011 | 10:05 AM
Em1L0ver's Avatar
Default Re: h2b need help asap
damn 57 view and no help at all come on hondatech
Old May 4, 2011 | 10:18 AM
dmfl666's Avatar
with the info you provided there is no way to help you, the rev problem is do to either the ecu , ignition components , timing
Old May 4, 2011 | 10:19 AM
eaperez209's Avatar
you got a fuel problem bud....are you running h22 injectors? if so did you wire up a resistor box? is the ecu ur running meant to run saturated injectors or peak and hold? make sure all your injectors are working properly and try to solder ur injector clips to make sure they are working as they should
Old May 5, 2011 | 04:57 PM
ricertek's Avatar
what ecu are you using?
Old May 5, 2011 | 08:05 PM
ki11id's Avatar
did you wire the vtec properly? looks like it wont rev hit vtec thats what i reckon
unless u have 2 step launch set in your ecu but it less likely the problem according to your video
Old May 7, 2011 | 09:49 AM
Em1L0ver's Avatar
yeah i already installed a resistor box so i no thats aint the problem
Em1L0ver's Avatar
stock 99-00 si/em1 ecu (P2T)
Old May 7, 2011 | 09:51 AM
Em1L0ver's Avatar
yeah with the vtec all i had to do was plug it in
Old May 8, 2011 | 10:45 AM
h2bej2's Avatar
take a look at your tps and map sensor wiring. make sure you dont have the two plugs mixed up.
Old May 8, 2011 | 05:33 PM
Em1L0ver's Avatar
no thats not the problem i already checked them and there fine,
NOW I WAS ON B20 AND THEY TOLD ME ITS MY ECU THAT I SHOULD GET A P28 AND I SHOULD BE FINE WHAT DO YOU GUYS THINK ???
Old May 8, 2011 | 06:00 PM
blown_ss's Avatar
[QUOTE=Em1L0ver;45220821]stock 99-00 si/em1 ecu (P2T)[/QUOTE
ding ding ding! i would start here. no you cant just use a p28! no STOCK ecu will work, well maybe a p13. you need to get a chipped ecu for YOUR set up. a p2t is for a b16 a 1.6l and you are trying to run a 2.2l from a different series. no trying to sound like a dick but lets use your brains people, stop trying to use stock ecus on swapped cars.
Old May 9, 2011 | 10:36 PM
Em1L0ver's Avatar
[QUOTE=blown_ss;45228253]
tru tru i deff agree with you on that, but give me some advise on what ecu to get i have no idea of witch one
Old May 11, 2011 | 07:34 AM
ricertek's Avatar
Use a chipped p28. Get it tuned on chrome
Old May 11, 2011 | 10:19 AM
Libertariat's Avatar
Ek Forever y0!
using your EM1 ecu is your problem. The motor is probably OBD1, or it should be, and you're using the wrong ecu. I'm surprised the car starts.
Old May 11, 2011 | 12:01 PM
SL0WEGG's Avatar
What code is the ecu throwing?
Old May 12, 2011 | 05:41 AM
blown_ss's Avatar
A p13 is a h22 ecu but you are not running a h22 so you need a chipped ecu
Old May 12, 2011 | 05:57 AM
Ek Forever y0!
Get a chipped p28 and get it tuned.
Old May 12, 2011 | 06:14 AM
ri_rv's Avatar
how did you wire up your resistor box? i bet that's the issue.
i had a friend who did his own resistor box and had the same exact issue like yours. car started and everything but would not rev pass 3500rpm, just because your car starts doesn't mean its wired right.
Old May 15, 2011 | 07:30 PM
vbolz's Avatar
yeah its should be the ecu.
gsrpowercrx
Mar 14, 2008 03:06 PM
DOHCtor Boost
Jul 3, 2007 07:29 AM
DelsoldS
Nov 14, 2005 04:32 PM
UnspokenTruth
Jun 8, 2004 09:16 PM
onePOINTsix
Apr 29, 2004 09:27 PM
