Injector Identification Help with pic
Old Apr 25, 2004 | 06:50 PM
onePOINTsix's Avatar
Default Injector Identification Help with pic
hey FI forum, need some help figuring out what these injectors flow and if they are peek and hold. They are both out of NA RX7s (the old *** lumps) all with red tops but 2 have red connectors and 2 have gray connectors. I picked them up from a local Junkyard for $20 for all 4 with clips All 4 have the part number 195500-1350 and DENSO on teh other side. I'm thinking these are Peak-Hold 460ccs but the connector color is throwing me off. Pic:
Thanks for the help!
Old Apr 25, 2004 | 07:30 PM
Default Re: Injector Identification Help with pic (Sideout)
No one knows?
Old Apr 29, 2004 | 03:57 PM
BlueCrxNC's Avatar
It is possible. You just need to add a resistor for each of the Peak and Hold Injectors (essentially the same as adding the injector resistor box which houses the resistors). You'll need to leave the other two (saturated) injectors alone (without the resistor). Sorry I don't know the resistor value.
ECU does NOT matter. It always sends out the same data.
Old Apr 29, 2004 | 09:27 PM
rioninja's Avatar
Everything ive always read bout the 7 injectors states that the second set of injectors is definatly smaller, somewhere closer to 240 or 310s.
Even though they have the same part number, i would definatly not just
throw them in until your sure. It is possible that someone replaced the smaller
pair with another pair of 460s, but dont count on that.
mortificationrock
Jun 10, 2007 09:05 PM
jackiechan
Apr 19, 2007 11:20 AM
joeyitr309
Apr 22, 2005 08:07 AM
joeski
Apr 16, 2003 08:33 PM
B20-T
Jun 22, 2002 11:29 AM
