When do you check your oil level?
Old Jan 11, 2004 | 01:35 PM
IloveNewt's Avatar
Default When do you check your oil level?
I normally check it in the morning after it sat for the njight so all the oil is settled down in the pan.
I notice that when i check the oil when im at a gas station or something like after it is warmed up, i check the oil after liek 10 mins and the oil level is different. Should i go by the oil level reading i get in the morning im guessing?
Also does oil changein volume in anyway with a change in temp? Like im running 20w50 now and it seems like it is like honey in the morning but when it gets warmed up it is more....fluid i guess. Does the volume change as it gets more "fluidy?"
Thanks....just some things i was ponderin...
Old Jan 11, 2004 | 01:45 PM
nsxmatt's Avatar
Default Re: When do you check your oil level? (MordecaiPSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MordecaiPSI &raquo;</TD></TR><TR><TD CLASS="quote">I normally check it in the morning after it sat for the njight so all the oil is settled down in the pan.
Thanks....just some things i was ponderin... </TD></TR></TABLE>
In the morning is the best time to check it. All the oil has had time to drain to the pan giving you the best reading of how much oil you have.
Oil is like most any fluid that is thicker cold than warm.
Old Jan 11, 2004 | 02:01 PM
lazerus's Avatar
Default Re: When do you check your oil level? (nsxmatt)
i end up checking my oil once a week or so, or when i notice oil that has dripped onto the pavement on the ground.. otherwise..
IloveNewt's Avatar
Yea i understand that there is a change in viscosity, but does that mean there is also a change in volume when it gets warmer as well?
Old Jan 11, 2004 | 02:10 PM
Bailhatch's Avatar
it may expand a bit but i'm sure it woulden't make much of a differance because it is pretty spread out in the pan so the level won't change as much as if it were in mare 'tall' shape like a thin vertical tube. Just keep checking it after it has drained for a while and your motor will be fine.
gwarfare
Feb 19, 2013 01:58 PM
XxRoCkMaNxNEOxX
Nov 28, 2004 09:17 AM
X2BOARD
Jan 13, 2004 03:30 PM
S13 slide
Oct 15, 2002 06:14 PM
B18Redline
Jun 10, 2002 11:35 AM
