h22 hybrid fuel pump
Old 10-26-2003, 10:09 PM
fast+forward's Avatar
Default h22 hybrid fuel pump
wanted to know if i would feel any difference on the "butt dyno" if i upgraded the fuel pump in my h22 ek? if so would the the prelude pump plug into civic?
any insight is much appreciated
Old 10-27-2003, 07:56 AM
Jason kiDD's Avatar
Default Re: h22 hybrid fuel pump (breakaway)
Your EK pump should do fine. However if you DO feel you have the need to upgrad then I would suggest the Walbro 190 or 255 gh pumps. Very inexpensive and work wonders..
Old 10-27-2003, 08:56 AM
citrusdrop's Avatar
how much hp can the 190 support
Old 10-27-2003, 09:12 AM
Jason kiDD's Avatar
Default Re: (citrusdrop)
Enough for most NA applications. But the 255 can be found for around $100 installed so it you may as well get that one. Just know that you WILL need a fuel pressure regulator to help bump down the pressure once it is installed..
Old 10-27-2003, 10:27 AM
hondaZvic's Avatar
Default Re: (Jason kiDD)
i was thinking about getting the warlboro 255, do u guys have a specific FPR that u would recommend?
Old 10-27-2003, 10:34 AM
Jason kiDD's Avatar
Aeromotive. The only way to fly..
Old 10-27-2003, 10:49 AM
hondaZvic's Avatar
which one? i found all of these.....
http://www.aeromotiveinc.com/p...ators
compact efi?
universal bypass?
hmm... not to sure about any of them..
Old 10-27-2003, 11:00 AM
Jason kiDD's Avatar
Default Re: (hondaZvic)
A1000 Injected Bypass Regulator, P/N 13101:
For 1000 HP applications that require flexibility.
Intended for use with custom fuel rails, this true billet regulator was designed specifically for use with our A1000 Fuel Pump.
Base pressure (vacuum/boost disconnected) adjustable from 30 to 70 PSI....
That one.. And it can be found for around $125 shipped..
Old 10-27-2003, 11:26 AM
junglerunna's Avatar
I installed the Walboro 255 lph fuel pump, but havent yet gotten around to buying a fpr and a guage, so I have not noticed any differences.
Old 10-27-2003, 06:35 PM
hondaZvic's Avatar
Default Re: (junglerunna02)
does a bigger pump affect the gas mileage much? i would think so, but would like to know from the experienced.
Old 10-27-2003, 06:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">does a bigger pump affect the gas mileage much? i would think so, but would like to know from the experienced.</TD></TR></TABLE>
A higher flowing fuel pump alone won't nesscarily decrease gas mileage excessivly. At least the mine hasn't.
Old 10-29-2003, 11:53 PM
kinvid22's Avatar
Installing a GSR fuel pump in a EK wouldn't necessarily need a fuel pressure regulator to control it on a stock B20 swap right?
preludedriva
11-30-2006 04:23 AM
Ddogz15
10-01-2004 05:23 AM
Kp_VtekNiks
10-11-2003 08:48 AM
bb6h22a
03-14-2003 10:06 AM
Kp_VtekNiks
01-27-2003 05:38 AM
Quick Reply: h22 hybrid fuel pump
