H22 Automatic Problems
Old Jul 19, 2006 | 07:27 PM
bardabe's Avatar
Default H22 Automatic Problems
Hey there guys. well alright I finally got the car going. everithing is fine. the car idles kinda low but that wont be a problem just gotta adjust the Idle. anyway my problem is that I took it for a test drive today and it drove pretty good for not having the Vtec ECU in yet. (still got the F22 one wiating in mail for Automatic P28 ECu adn TCU) anyway the problem is I am getting a Code 22 on the CEL (Vtec pressure switch gotta recheck wiring) and then the D4 Light blinks when I am driving. and when I went to do the CEL check. the D4 light was flashing 9 times and pausing flashing 9 times and pausing. what does that mean?? any help/ sugestions. (also there is a loud squealing/rubbing/ clicky noice coming from the front of the motor in the section where you check the timing.)
-Juantons
Old Jul 20, 2006 | 09:59 AM
bardabe's Avatar
Default Re: H22 Automatic Problems (bardabe)
is there anyone in this world that can help me... I am pretty much stuck... *sigh*
Old Jul 20, 2006 | 03:00 PM
v4lu3s's Avatar
RTFM
code 9 on teh TCM is for:
-loose or bad connection between tcm and body harness
-disconnected countershaft speed sensor
-short or open in countershaft speed sensor wire
-faulty countershaft speed sensor
Old Jul 20, 2006 | 05:38 PM
JasonST's Avatar
Default Re: (v4lu3s)
Check ur oil pressure, remove the pressure siwtch and try to clean it. Also the ticking noise sounds like the valves ticking, probly mean u'll need to do a valve adjustment soon. G ood luck.
VtecFreePrelude
Engine Management and Tuning
Jun 27, 2010 11:26 PM
H22Ej2
Aug 14, 2006 06:01 PM
nosegrindR
Apr 19, 2006 11:28 AM
H22A_EJ2
Jan 29, 2006 05:56 AM
COMplex.
Jul 17, 2003 05:51 PM
