h22 99 si
Old Dec 21, 2003 | 10:56 AM
92gsrhatch's Avatar
Default h22 99 si
ok i have read all the 96-up info and still i cant seem to find out what ecu or wiring harness to use on my 99 si for the h22. the only reason i did this in an si is because it was a stolen recovery and i got it cheap with an ex motor in it. i got a 98 h22 to go in and i need to know what to do about the crank sensor. any help or diagrams would be appreciated.
Old Dec 21, 2003 | 03:33 PM
SilverEk3dr's Avatar
Default Re: h22 99 si (92gsrhatch)
You really wont need to rewire anything but the distbutor (if its external coil). Just cut open the harness, and retrace the plugs to where they will all reach around the H22. You shoulndt need to add any wire (unless you are gonna use the iab's, but there worthless) The tdc, and ckp censor can be wire from the existing wires that you wont use from rewireing the distributor.
Old Dec 21, 2003 | 04:18 PM
fast+forward's Avatar
Default Re: h22 99 si (SilverEk3dr)
https://honda-tech.com/zerothread?id=650329
vtakk eg
May 6, 2009 04:01 PM
Aaran
Jul 27, 2005 10:56 PM
SprayinCX
Apr 10, 2005 02:35 PM
tricura
Mar 1, 2004 04:22 AM
Zane
15
Aug 10, 2002 04:31 AM
