Fuel Pump ?
Old Aug 12, 2001 | 02:10 PM
Double 06's Avatar
New User
Default Fuel Pump ?
Is the ITR stock fuel pump the same as lets say the GSR or Si? I would say the SI no, but the GSR should be the same right?
I'm in need of a stock fuel pump.
Old Aug 12, 2001 | 03:59 PM
FSTASNTZ's Avatar
Default Re: Fuel Pump ? (Double 06)
Si, GS-R and ITR should all have the same flow ratings.
An option is a 1G or 2G eclipse pump. They can handle a few more PSI, but not by much. If you want one of these, let me know, I have one of each that I used at one time just for testing.
Jason
Old Aug 12, 2001 | 05:12 PM
JDM R98's Avatar
Default Re: Fuel Pump ? (FSTASNTZ)
so you saying that a G1 or G2 Eclipse would fit right in a Type R and do good?
Old Aug 12, 2001 | 05:25 PM
Double 06's Avatar
New User
Default Re: Fuel Pump ? (JDM R98)
good that helps me out alittle, i just need a stock pump, so i can work out the ups and downs of my hondata and drag III, unless the gss317 walbro won't hurt being n/a until i get the turbo and hondata and injectors in....
Let me know what ya'll think i should do.
1. Leave GSS317 pump in
2. Get a stock pump
Old Aug 12, 2001 | 07:43 PM
FSTASNTZ's Avatar
Would I buy a 1G or 2G elcipse pump for an upgrade? No. They only supply slightly more pressure. What I mean by that is the stock pump holds steady at 60-62 PSI on 310 injectors, the stock 1G and 2G pumps held about 65-68 PSI with 310 injectors. If you are to the point of needing a higher volume pump, buy a Supra TT or Walbro pump, if you are in a pinch and cannot find a stock pump, the 1G and 2G Eclipse Turbo pumps will fit, work just fine and supply you with plenty of fuel.
If your stock pump cannot supply enough fuel, then chances are that the 1G and 2G Eclipse Turbo pumps will not get you to where you need to be.
Jason
Old Aug 12, 2001 | 10:37 PM
sgT's Avatar
sgT
Just leave the walbro in. You'll be fine until you get the turbo setup.
Old Aug 13, 2001 | 02:07 PM
Double 06's Avatar
New User
Default Re: Fuel Pump ? (sgT)
ok, just making sure the walbro 317 won't be too much fuel for a stock ITR, until i get the turbo in, then i'll guess i'll keep it since, i'm going to be going with some larger injectors and hondata.
thanks SGT....
May need to drive up there for the tuning process (hondata) but doug said the closest to me is in columbia, sc.
Old Aug 13, 2001 | 02:16 PM
sgT's Avatar
sgT
well, its up to you. If you want to come up here thats fine by me.
I'll be glad to help you out.
ridnmyhonda
Apr 1, 2003 01:00 AM
1tyme
Oct 22, 2002 12:36 PM
GSR_Dude
Oct 25, 2001 11:28 PM
smoothludey2
Oct 18, 2001 06:06 AM
