P30 sol with jdm b16 ecu problems
Old Sep 26, 2004 | 01:27 PM
birds_sol_94's Avatar
Default P30 sol with jdm b16 ecu problems
ok i got p-30 jdm motor and the only difference between the p30 i had it in and the jdm one is the evap purge control valve/syl. and i was wondering not having that in can throw a map sensor code if not y am i throwning a map sensor code ive dont went throw 2 map sensors and i know they both can be bad! and if anyone knows what are the colors for the wires on the knock sensor are?????
Old Sep 26, 2004 | 02:07 PM
XzzYzzX's Avatar
Default Re: P30 sol with jdm b16 ecu problems (birds_sol_94)
the knock sensor is located on the back of the block u should of got the knock sensor off the jdm harness and ran your own wire to the p30....not sure about your map sensor problem..bump for this man...
Old Sep 28, 2004 | 07:50 AM
Default Re: P30 sol with jdm b16 ecu problems (XzzYzzX)
bump
Old Sep 28, 2004 | 04:33 PM
smart monkey's Avatar
having the evap or not should not throw a engine light for map. make sure that maps o ring is good or not leaking or test the map using specs from a manual.
Old Sep 28, 2004 | 05:08 PM
Katman's Avatar
I can't recall if the EVAP & MAP sensor plugs use the same style of plug, but perhaps you confused & crossed the EVAP & MAP sensor plugs. Double check that. And reset your ecu while your at it.
Old Sep 28, 2004 | 06:25 PM
Default Re: P30 sol with jdm b16 ecu problems (Katman)
thanks for the info... does anyone else have anything they might know! im thinking i might have a leak in the throttle body but i think that was just cause inrregular idle... but ill check the map sensor... but i dont have my manual with me if anyone can inform me on how to do that right now i would appreciate that much! thanks again
Old Sep 28, 2004 | 08:44 PM
builthatch's Avatar
MiG-21 superfan
good god ill say it again: what the **** would we do w/o Katman?! - http://www.ff-squad.com/technet/
peep it.
Old Sep 29, 2004 | 01:41 PM
Default Re: P30 sol with jdm b16 ecu problems (builthatch)
didnt help much on the site there... thanks tho..anyone else know anything..!
bump
cleanazcoupe
Jul 1, 2009 07:53 PM
95b16rr
Oct 10, 2008 05:11 PM
mattmw88
Apr 11, 2005 05:46 PM
