engine stalls...
Old Jun 20, 2001 | 11:33 AM
speedjunkeez's Avatar
Default engine stalls...
lst gen b16a,j1tranny,pw0 in my lil rexy..
Ok heres the problem..now..I'm able to start the motor
will no problems at all.
as soon as it gets to operating temp..the engine
stalls..throws no codes what
so ever...air fuel guage indicating that i'm running
sufficient fuel..even my fuel
pressure guage is a all go too @ 40 psi...so definetly
can't be a fuel thing.
I just replaced my coil and cap..since it was charred
when this situation occured..
which i though would solve the problem..but still a no
go situation..I also checked
spark by grounding a spark plug wire to a ground
chassis. Turns out i got spark
I have checked all connections,possible fuel leaks all
the way up to the injectors,
other distributor components, still puzzled.......
no codes, no damn clues..
engine just shuts down as soon as it gets warmed up...
I would definetly appreciate the feed back guys cuz my
*** is
stuck like chuck...TIA
-Ron
Old Jun 20, 2001 | 12:00 PM
DragII's Avatar
Default Re: engine stalls... (speedjunkeez)
look for a vaccuum leak
Old Jun 20, 2001 | 12:58 PM
Default Re: engine stalls... (DragIIcivic)
no vaccum leaks what so ever sir...
Old Jun 21, 2001 | 10:38 AM
markaria's Avatar
I'd check the main fuel relay
BONNARSKI
12
Jan 7, 2013 02:42 AM
GhostInTheShell
May 30, 2006 02:31 PM
oxSLEEPERxo
17
Mar 17, 2005 08:03 PM
biggmike2
Jan 21, 2004 10:56 PM
speedjunkeez
Jun 21, 2001 12:11 AM
