replaced engine: got fuel got spark wont start?
Old 01-21-2004, 07:33 PM
biggmike2's Avatar
Default replaced engine: got fuel got spark wont start?
its a 96 civic hatchback, blew engine when it dropped a valve and put a hole in my piston car just shut off but would crank when this happened. replaced engine and found out when engine went messed up the coil inside the distributor too so i replaced the entire distributor now it still wont start/run it will crank and i got spark and fuel but it wont run or even try to run, almost like its starting but not getting spark but i check and it is. anything else i should check beacause iam running out of ideas. Thank You Ahead of Time for the Help
BiggMike
Old 01-21-2004, 07:55 PM
biggmike2's Avatar
Default Re: replaced engine: got fuel got spark wont start? (biggmike2)
anyone?
Old 01-21-2004, 10:00 PM
I'm really 2slow
2fast4u831's Avatar
did u try checking the vacuum lines and the censors??
Old 01-21-2004, 10:56 PM
In The Garage
Shawn C's Avatar
you have fuel and you have spark. you sure? do a compression test on the new engine. check that the spark plug wires are in the correct order.
kaputhonda
05-28-2013 11:56 AM
Maidumechanic
02-14-2013 05:39 AM
HondaRexBoi
05-13-2008 12:08 PM
knomexx
07-14-2005 08:13 AM
Big_b_69er
01-24-2002 09:07 AM
Quick Reply: replaced engine: got fuel got spark wont start?
