obd1 del sol engine harness
Ok ive looked aeound but havnt found the answer. I need the part of the harness that connects to the injectors and engine and trans. Its a 94 del sol b16 so if i get the harness from an obd1 integra it would plug up and work? If not then i have to order it from ebay or drive 2drs amd get one... thanks
Re: obd1 del sol engine harness
not all the harnesses are the same. as long as motors are the same, then they match up.
93 DX harness will not be fully compatible with a 95 EX. vtec will not work unless its added in to the harness. all 92 model civics were pre wired (chassis harness) for vtec so this year is an exception.
and GSR engine harnesses will be wired for knock sesnor where as the civics did not have them
So they will hook up to the sol harness? My engine harness from the del sol is tashed... The po cut off the injector connectors and ripped up the harness itself cutting different places bit i got all the other harnesses for it and just need the engine one. I believe there still moght be 2 integras in the yard i go to so would one fit i gotta see what year but i think they are pre obd2
Technical Hero
You'll want 92-95 civic DX/LX/EX. The VX and most CX have different 02 plugs. 92-95 Integra all models will work and be plug and play, the GSR will have some extra plugs for vtec, knock and IABs you can ignore.
CaptinMcnut
11-12-2004 05:01 PM
