ECU Connector Compatibility
Old Jul 3, 2002 | 04:21 AM
EE_Chris's Avatar
Default ECU Connector Compatibility
This thread is about wether or not a 96-97 Del Sol ECU would plug into a 96-98 EX harness. As indicated by Katman's rule of thumb: 96-98 Civic/Integra ECU's will plug into any 96-98 Civic engine harness.
Well, what about us 99-00 Civic guys? What ECU's plug directly into our connectors without modification (besides the Si ECU)?
Old Jul 3, 2002 | 06:29 AM
kenji's Avatar
25 Year Member
Default Re: ECU Connector Compatibility (EE_Chris)
If you are referring to B-Series DOHC VTEC ECUs a '99-'00 JDM CTR ECU will plug in. As will a '00-'01 JDM ITR ECU. With the ITR ECU you will need to move A15 to A16 on your engine harness ECU plugs.
A '00-'01 USDM ITR ECU will plug in as well but you will need to have the immobilizer removed. The same holds true with moving A15 to A16 in this case as well.
-kenji
Riley Martens
Apr 9, 2016 12:46 PM
jdmnovice-21
Feb 17, 2009 06:00 PM
BLKCivicPorscheStyle*
Aug 22, 2005 12:46 PM
JDM CTR EK
Mar 24, 2005 03:54 AM
