Doing H22a swap into 98 Teg... problems with the axles!!!
Old 05-16-2005, 02:02 PM
Sivik's Avatar
Default Doing H22a swap into 98 Teg... problems with the axles!!!
OK, I've read up on what you need for this swap. We have everything or thought we did. I ordered a 90 Accord Half Shaft with the 90-93 L and R Integra axles. Got the half shaft no problem... went to put it in and both of the ends are male ends, as well as both of the ends for the axles are male ends. The problem is that my buddies who one is a Honda tech and the other has done this swap before say that the half shaft is wrong. It should have a male and female end. I've also asked numerous people who have done the swap already and they said the half shaft has both male ends and the axles are one male and one female. Need help ASAP please! Thanks!
Old 05-16-2005, 05:06 PM
simon98h22's Avatar
Default Re: Doing H22a swap into 98 Teg... problems with the axles!!! (Sivik)
I have the same motor and shell and used the lude midshaft and 86-89 teggy axles. From what I read though, your combo should be right (90-93 accord half shaft with 90-93 teggy axles) ... weird. Both ends on your midshaft are female?
Old 05-16-2005, 05:32 PM
Sivik's Avatar
no both ends of the half shaft are male
Old 05-17-2005, 11:05 AM
alleyezonme's Avatar
Default Re: (Sivik)
then you must have got the wrong parts, b/c with your setup it should have worked. the intermediate shaft has a male and a female end and you hook up the teg male into the intermediate female. and the same thing on the other side (without the intermedaite shaft). don't forget to swap out lude ends on the teg axles or else it will probably constantly pop out.
Old 05-17-2005, 05:26 PM
Sivik's Avatar
yea we figured out the shaft was wrong... i read about the swapping of the lude ends... is this necessary because they will fall out constantly or can i get by for the time being?
Old 05-17-2005, 11:17 PM
MrMike's Avatar
Default Re: (Sivik)
the accord intermediate shaft has a female end where driverside axle goes into. u probably got a prelude intermediate shaft.
Old 05-18-2005, 12:04 AM
Sivik's Avatar
so the prelude intermediate shaft has both males ends?
Old 05-18-2005, 12:05 AM
Sivik's Avatar
Default Re: (Sivik)
this is the shaft i got? anyway to make it work? or is it the same as the JDM H22a shaft?
Old 05-18-2005, 12:50 AM
MrMike's Avatar
Default Re: (Sivik)
yeah thats a prelude shaft. to make that work u need 86-89 integra axles with prelude inner CV joint.
Old 05-18-2005, 07:11 AM
Sivik's Avatar
ok thanks a bunch man!
SiRTifiedacc
06-26-2005 06:08 PM
4gen
08-11-2003 04:02 PM
4gen
08-09-2003 08:26 PM
4gen
08-05-2003 05:41 PM
b18crx
05-26-2003 06:28 PM
Quick Reply: Doing H22a swap into 98 Teg... problems with the axles!!!
