distributor problems (B16 in CRX)
Old 12-22-2004, 04:41 PM
TeaminlineB16's Avatar
Default distributor problems (B16 in CRX)
Alright.....its not the actual distributor....its the cap....its craked and old.....i changed the spark plug wires and discovered this.... My problem is buying a new one!Where do i get a cap for a B16 OBDO? MSD has pictures on their website and tey have one that matches my motor but its for a CRX Si......is this right? will it work?By the way.........the motor is not in yet because im prepping it.Good thing too.....
Old 12-22-2004, 05:27 PM
smart monkey's Avatar
Default Re: distributor problems (TeaminlineB16)
get a 90-91 ls or you can even use a 88-91 civic just have to trip the little notch in the cap. you will see what I am talking about if you do it.
Old 12-22-2004, 05:31 PM
Default Re: distributor problems (smart monkey)
if i use the 90-91 LS i dont have to do any modding? But with the 89-91 i do? I want to get one from MSD, which do you think is best (which would YOU get?) the LS or the 88-91?
Old 12-22-2004, 06:11 PM
keithg's Avatar
Get a factory Honda/Acura cap for a 90-91 Integra. It will be better quality than any aftermarket cap and (I am guessing) it will probably cost less than an MSD cap.
Old 12-22-2004, 07:18 PM
no real need to mod and if you did it is so easy to do. I would only get the msd one if you are using msd but even if so you could just mod the stock oem cap to run msd also with a power tower.
92redhatch
09-07-2007 08:25 AM
Tdemsko
05-25-2007 10:55 PM
69crx
05-18-2006 07:57 PM
Quick Reply: distributor problems (B16 in CRX)
