obd2a to obd2b wiring distributor help please
Old 10-02-2006, 05:26 PM
BlackEG6's Avatar
Default obd2a to obd2b wiring distributor help please
most of the colors match up except 2 wires.... can anyone tell me where these wires go please....
or am i even wiring this up right? =/
thanks
Old 10-02-2006, 07:45 PM
BlackEG6's Avatar
some help please!
Old 10-02-2006, 07:51 PM
y7turbo's Avatar
Default Re: (BlackEG6)
i just wired a obd2A plug on an obd2B dizzy. not all wires matched colors. you have to look inside both dizzys and trace the wires and go from there. i know the obd2B the blue wire wasnt used and i had to add one when going to obd2a. but that was on a single cam i dont know what your using
Old 10-02-2006, 08:31 PM
BlackEG6's Avatar
Default Re: (y7turbo)
ok i figured out most wires...
just the blue wire left. ENGINE SPEED OUTPUT.
does anyone know how to hook this up?
Old 10-02-2006, 08:36 PM
y7turbo's Avatar
Damn where did you find that? well on your chart it says some are orange, i guess mine could be, they look more pink to me though.
well like i said i did the exact opposite so i made a diagram for you. The obd2a plug on obd2 dizzy wires are correct, cause i did it but i made the chart and reversed my conversion so it should be 100% correct for your obd2a to b conversion as well.. your lucky i was in a good mood to make this.
good luck.
Old 10-02-2006, 08:46 PM
BlackEG6's Avatar
thanks man
.........BLUE?.............
Jhonny Ricer's Avatar
put this up in the archives
Old 10-02-2006, 10:04 PM
y7turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
.........BLUE?.............</TD></TR></TABLE>
the obd2a had a blue wire, its for the rpm it goes onto the ignitor. my obd2b didnt have it and i had to add the wire.. so the obd2b must get its rpm signal from somewhere else.
post back so we know how it went.
Old 10-03-2006, 09:16 AM
BlackEG6's Avatar
bump for any help
Old 10-03-2006, 10:09 AM
sicones's Avatar
the 96-98 OBD2A has an extra Tach output wire, I think it's solid blue, just ignore it, also near the driver side firewall behind the shock tower is a little black rubber cover over an empty connector this is the same Tach output wire that is connected to the gauge cluster, it used for adjusing engine idle speed with a digital tach
OhShift!
10-05-2012 05:32 PM
DVS Luder
10-11-2007 03:47 AM
iheartamy
12-23-2006 08:43 AM
HKSone
07-10-2003 04:53 PM
OutLuDeD
03-01-2003 07:50 AM
Quick Reply: obd2a to obd2b wiring distributor help please
