D16Y7 OBD1 questions??
so im piecing together a sohc swap and turbo kit for my 95 cx, I will be buying a y7 w/ harness but no ecu . I want to stay obd1 so i can chip my ecu and run uberdata, can I use the cx ecu and wiring harness? If im using the cx harness do i need to change anything? ( The car currently has a one wire o2 sensor) if I use the y7 harness can I stay obd1 without having to buy an adapter harness to the ecu?
I have searched and came up with one post that had any info saying I could use the cx harness but to keep the cx intake mani, well the y7 already has a different manifold on it, although I'm not sure which one but its definitely not a stock y7 intake manifold
what i would do is:
run the y7 with ur stock existing harness and computer and dont use a stock y7 intake manifold cause they have no place for iacv
im not sure if u can get the obd2 distributor to work on it, u can just use ur stock one tho.
dont use the y7 injectors cause they are not programmed for ur po6 ecu that i assume u have in ur car,
thats all i have to offer good luck!
great info thanks, the y7 already has a normal(non vertical tb) intake mani on it but I have only seen pictures of it so i dont know what mani it is, but it should have
iacv
iacv
yeah I know, i thought I might end up having to get a conversion harness, but I guess not. What difference does the o2 make if I use the stock cx harnes and o2? any?
CX ecu reads 1 wire, all others besides HX read 4 wire
so if you want a 5k redline use the cx ecu with the cx harness
it say find a p06 and change the wire harness to 4 wire o2
mdoyle
May 25, 2006 11:01 AM
