will a b18b ls power steering fit onto a gsr?
need a new power steering pump cause threads are stripped.. i'm wondering if a DB LS power steering pump will fit onto my gsr block?
will the brackets be a problem?
Re: will a b18b ls power steering fit onto a gsr?
First, which threads? Maybe drill the threads out and use a longer bolt with a nut on the other side if it's the pump to bracket bolts.
And IDK about the interchange on that. I think the bracket is different, pump should be interchangeable. You could look the part numbers of both up to see if they're a different part.
JussHatched
04-24-2006 07:53 AM
