power steering problems on 99 ex civic
hey guys i just recently swapped a 99 ls swap into my civic and i want to retain power steering, my question is what high pressure hose can i buy that will bolt on to my new power steering pump?
i've tried the cr-v bracket and my old sohc power steering pump and the pump isn't able to adjust in any way to take slack out of the belt..
tia
tia
Maybe a DOHC Del Sol bracket? 99-00 Civic Si?
Edit: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/
That is strange, I heard the CR-V bracket works on 96-00 Civic's with B18B/B20 swaps on the original power steering pump - Have you tried using a different (shorter) belt?
I suggest to use the CR-V bracket with a CR-V ps pump or LS upper and lower brackets with a 98-01 LS pump or 99-00 Si pump.
Belts:
99 CRV PS Belt is 911mm long (outside circumference).
99 Integra LS/GSR/ITR PS Belt is 932mm long
Looks like if you are using a CRV Bracket, you should use the shorter CRV belt. I am guess he is trying to fit the longer Integra Belt on your car?
ZoobeaR
06-04-2002 06:35 PM
not7fifteen
04-30-2002 10:26 AM
