AC compatibility for GSR swap
GSR swap going into stock EJ1...can I use the compressor and lines off my EJ on the GSR block or do I have to buy a B series AC system?
Re: AC compatibility for GSR swap (Speed94)
Buy a 96ish del sol dohc ac bracket or a 98ish crv ac bracket, and by bracket i mean the peice that the compressor bolts to.
Re: (Speed94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by girlsaremean »</TD></TR><TR><TD CLASS="quote">Buy a 96ish del sol dohc ac bracket or a 98ish crv ac bracket, and by bracket i mean the peice that the compressor bolts to.</TD></TR></TABLE>
ABSOLUTELY WRONG!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed94 »</TD></TR><TR><TD CLASS="quote">and that all I need to bolt my d series ac compressor to my b series and get it working?</TD></TR></TABLE>
you will need the P7J(crv) or the P54(94-95 del sol) bracket. if the motor you have already has a compressor bracket then all you need is the new bracket.
if not, you will have to buy the tensioner and pulley as well.
i do recommend you go with the P7J bracket because for some reason Honda had it with a lower list price, but they are exactly identical.
ABSOLUTELY WRONG!!!
Re: (philosofy1)
x2 I had me Ej1 with the Ls motor and the best Fit bracket was from the delsol vtec model (i learned the crv was the same afterwards) I have a friend at the dealer so it cost me 90 bucks but small price to pay to keep your AC.
slowpokesi
17
07-20-2002 08:31 AM
