Engine is choppy or is missing at low rpms
Old Nov 15, 2012 | 10:38 PM
Bsixteen_CRX's Avatar
Default Engine is choppy or is missing at low rpms
So I've searched and just can't find a definitive answer. I just swapped a b16 into a 89 crx si, I pulled it out of my other wrecked crx in which it ran absolutely perfect. Now it fires up first try every time but when I drove it it was really choppy/missing at lower rpms. Like idle to 2200 or so, then, after that it pulls just fine. My old crx had a stock fuel pump and the new was has something after market, not sure what it is but it sounds pretty burly, like at least a walbro 255 or something. The car used to be boosted according to the previous owner. I was wondering if its required to run an after market fuel pressure regulator with a bigger fuel pump. Also it has a golden eagle fuel rail.
Thanks for any help
Old Nov 17, 2012 | 07:25 AM
SPOOLINmatt's Avatar
Default Re: Engine is choppy or is missing at low rpms
spark plug wires, rotor button, plugs
Old Nov 17, 2012 | 03:15 PM
PhilStubbs's Avatar
Sounds like tps needs to be adjusted
Old Nov 19, 2012 | 02:18 AM
Well the thing is it ran perfect in my other crx and that was barely a month ago. Pulled it out it sat for a couple weeks, properly covered up and stored. Then swapped back into new car. So I don't think new wires or plugs are necessary.
Old Nov 19, 2012 | 03:21 AM
PhilStubbs's Avatar
Does it also do it with no load just in neutral?
Old Nov 19, 2012 | 11:24 PM
No it revs just fine, it does idle really low.
Old Nov 21, 2012 | 01:09 PM
Never mind it does it with or without a load on it so.... Tps? Maybe. Or fuel pressure problem? I can't figure it out.
Old Nov 21, 2012 | 03:48 PM
PhilStubbs's Avatar
Adjust the tps. Move it the direction to simulate the throttle opening. What's happening is the ecu sees a closed throttle so it kills the injectors till the engine comes down to idle rpm, then it squirts fuel again, rpm rises and it cuts fuel thinking you are decelerating. If you (I call it) advance the tps, then the ecu sees that the throttle is open and doesn't cut fuel.
Old Nov 21, 2012 | 04:49 PM
Ok ill try that, see if it works. Thanks
akinas-crx
Engine Management and Tuning
Nov 13, 2011 06:52 PM
Oldboyoh
Sep 21, 2011 10:12 PM
masterpenguin15
Classic Hondas
Jul 14, 2009 04:28 PM
oakpwr
Oct 25, 2008 05:54 PM
yorace2win
Oct 21, 2002 09:13 AM
