CRITICAL HELP: Engine Harness related question.
FS: Engine Harness
I have a 1997 Civic DX, with a B18C5 motor and 97 itr P73 ecu.
Will the 1997 Del Sol B series engine harness plug right in without any modification?
Reason for asking is because I am having problems with my existing modified DX engine harness.
Thanks
Modified by oem at 9:15 PM 10/17/2004
Re: (SpoonFedHatch)
No No No No. A del sol harness will not fit in your 96-98 civic. The civics are about the only hondas that have one peice harness' that go all the way to the ecu. You must use a 96-98 CIVIC EX harness. This is the only one you can use. You cant use 99-00 because it wont work with the dash wiring. Beleive me cause ibe swapped the motor in my 97 DX 4 times. Good luck.
