code 3 problems
Old Jul 5, 2001 | 03:09 PM
synergy004's Avatar
Default code 3 problems
damn motor, LS built from bottom up with my custom turbo set up is throwing a code 3. IT idles at 2k RPM constant and wont seem to lower itself even after long idle period. I tried lossening the throttle cable and adjusted the screw on the TB, still didnt work, then tried adjusting the damn distributor but that only made it go to about 1800 RPM still steady there. Any other suggestions. Thanks
Old Jul 5, 2001 | 07:10 PM
Jared's Avatar
Default Re: code 3 problems (synergy004)
Sounds like your MAP sensor isn't seeing enought vacuum.
good luck,
Jared
1337 Si
Oct 2, 2008 01:59 PM
smokinsi
Jul 18, 2004 05:09 PM
Just2Fast
Jul 17, 2001 12:11 PM
synergy004
Jul 6, 2001 11:52 AM
synergy004
Jul 6, 2001 11:45 AM
