selective vtec problem.....
Old Sep 22, 2004 | 08:06 AM
punkassazn's Avatar
Default selective vtec problem.....
hey there dudes and dudets. my engine code is telling me 22. that's vtec solinoid right? my vtec comes on and off. faulty wiring maybe? and when my vtec doesn't kick in the check engine light comes on when my revs get too high. n e one had this problem before? or does ne one know how to solve this? lemme know. thanks and have a great day.
Old Sep 22, 2004 | 08:23 AM
JimBlake's Avatar
Default Re: selective vtec problem..... (punkassazn)
22 is the VTEC oil pressure switch, not the solenoid. That one can be caused by low oil level. Make sure your oil pressure's OK. Otherwise, check wiring to the switch.
Old Sep 22, 2004 | 08:59 AM
bk92teg's Avatar
Yea as before, code 22 is VTEC pressure switch, I had the same problem almost, my VTC would engage but it would cut off at 7500rpm's, and the code 22 popped up, so we tried changing the sensor (the little green plug), and it broke on us so we put an entire new solenoid on it and now it works perfect, i didnt know what it was at first cause i had just changed the oil so i knew it wasnt low oil or anything, just hopes that helps you a little
Brian
Old Sep 22, 2004 | 03:30 PM
punkassazn's Avatar
Default Re: selective vtec problem..... (JimBlake)
you mean like the oil to my car? how would i check the pressure?
Old Sep 24, 2004 | 06:16 PM
punkassazn's Avatar
i could sure use some more advice guys!!!
Old Sep 24, 2004 | 06:30 PM
Droppedatbirth!'s Avatar
if your not sure of what your doing dont try to fix it yourself. to check oil pressure you need an oil pressure gauge. it should be around ten psi at idle and go up to about 40 psi by 2500 rpm. if their is not enough oil pressure your vtec will not engage since it is more important to feed the engine oil instead of your vtec. if it is low oil pressure it could be a # of things. it also has to do with engine bearing wear and tear and wear of other angine components. if you not sure take it in to honda service and they will diagnose your problem for about 80 bucks.
Old Sep 24, 2004 | 06:42 PM
punkassazn's Avatar
Default Re: selective vtec problem..... (Slammed)
thanks bro. i'm taking it to a honda specialist on tuesday @ 8am. i hope i can get the problem fixed in a hurry.
Old Sep 25, 2004 | 11:41 AM
punkassazn's Avatar
maybe i'll get the problem fixed today!
Old Sep 25, 2004 | 04:43 PM
punkassazn's Avatar
looks like it's fixed. we'll have to see if it holds up a few weeks later. basically i just took off the whole solenoid and cleaned it out. there was lots of debris in there. i hope it lasts.
Old Sep 25, 2004 | 07:35 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkassazn &raquo;</TD></TR><TR><TD CLASS="quote">looks like it's fixed. we'll have to see if it holds up a few weeks later. basically i just took off the whole solenoid and cleaned it out. there was lots of debris in there. i hope it lasts.</TD></TR></TABLE>
Even if you have to do this every year or 2, that's not a horrible fate.
Old Sep 27, 2004 | 12:45 PM
punkassazn's Avatar
well nevermind....it didn't work. taking it to a shop on tuesday morning.
Old Sep 28, 2004 | 06:43 PM
punkassazn's Avatar
anybody ever heard of a oil restricter valve??? the honda mechanic said that that's what's probably holding the oil back from the head and solenoid that's why my vtec isn't working....ttt
Old Sep 29, 2004 | 03:46 PM
punkassazn's Avatar
ttt
Old Oct 1, 2004 | 12:13 PM
punkassazn's Avatar
fixed! i was missing the oil pressure valve!!!! i think that's what it's called!!!
94wip
12
Jun 20, 2024 07:23 PM
jdm-as-f@$k
18
Jul 10, 2010 09:11 PM
drudy
Aug 26, 2005 12:20 PM
hierohed
May 27, 2005 10:17 AM
SoCal ITR
Feb 23, 2005 08:58 PM
