car runs better with check engine light
Old Oct 29, 2010 | 06:51 PM
ryanangelo212's Avatar
Icon2 car runs better with check engine light
so just out of curiosity id figure is ask...
on my current car (b16 da) vtec wont work until i get the light (after a few seconds of driving) and on my old crx ls swap it bogged terribly until the check light came on.
odd, though ive heard of other people having the same thing.
Old Oct 29, 2010 | 07:06 PM
Spawne32's Avatar
Default Re: car runs better with check engine light
the details are overwhelming
Old Oct 29, 2010 | 08:52 PM
koss1229's Avatar
I would say, if an O2 or Map sensor (or some other sensor) readings are false, your ECU is trying to adjust fuel ratio according to that info, but when a CEL comes on, the sensor is considered bad and no adjustments would be made, so that you feel it works better, but its still not good. Read the code and replace the faulty sensor
Old Oct 29, 2010 | 10:09 PM
el crapitan's Avatar
^^basically, yea. when the light comes on, the pcm goes into what's called open loop mode, running off set parameters stored in the pcm. as opposed to closed loop, where the pcm receives feedback from (a) sensor(s).
so when the pcm is in closed loop, and the sensor is faulty, it will receive faulty readings from it until it recognizes a problem and goes into open loop
Old Oct 30, 2010 | 05:02 AM
HondaPartsHero's Avatar
Technical Hero
So what code is the cel throwing, that might be a good place to start.
Old Oct 30, 2010 | 10:19 AM
well, the crx is long gone now but the b16 throws knock sensor code THEN vtec works. really odd. first vtec didnt work, then after i fixed it (it was the knock) this happens. not a worry, more of a curiosity.
realmike15
Honda Civic (2001 - 2005)
Nov 12, 2010 09:38 AM
7mile
Jul 1, 2010 02:10 PM
thegod
Aug 9, 2008 07:27 PM
Kent in KC
Jan 7, 2008 01:08 PM
AznInvasion
Nov 29, 2007 08:59 AM
