ECU won't give code
Old Feb 17, 2005 | 01:43 AM
LsVtec98's Avatar
Default ECU won't give code
So i had my ls/vtec swap done about a month ago. Right before i had the swap done my maint req. light came on, so i took it to autozone and they ran a diagnostic telling me it was my Secondary O2. It ran fine and everything until i had the swap done, it chugs now and keeps dropping rpms like its going to stall out. After the swap i took it to autozone again because now my check engine light started coming on only after my car was out of loop mode. It does this everytime i shut my car off and turn it back on now. I took it to autozone again, and they can't get a reading. I also tried jumping it and the check engine light doesn't even come on when its jumped. Has anyone heard of or had this happen to them?
Old Feb 17, 2005 | 04:09 AM
mr.beeks's Avatar
Default Re: ECU won't give code (LsVtec98)
its your idle valve control...
you will never get a signal from this...
viciousef9
Jun 14, 2007 03:49 PM
PhatwhipsJDMkits
Nov 28, 2004 03:46 PM
PhatwhipsJDMkits
Nov 27, 2004 11:47 PM
kayoken
Feb 5, 2003 08:12 PM
milo
Dec 5, 2001 06:27 PM
