CEL code 22 help....
Old Mar 23, 2006 | 06:39 AM
lshatch92's Avatar
Default CEL code 22 help....
got a b16 CEL code 22 on start up not really to sure what to do i no it could be bad VTEC solenoid valve, Bad VTEC pressure switch has oil i took the solenoid off it look alright has anyone had this problem? any ideas what to do?
Old Mar 24, 2006 | 01:44 PM
lshatch92's Avatar
Default Re: CEL code 22 help.... (lshatch92)
no one? put NEW VTEC solenoid valve,VTEC pressure switch still no difference WTF SOMEONE HELP!!!!
Old Mar 26, 2006 | 06:15 PM
f2m0u5's Avatar
i got the same code, im searching right now to find out.. ill let you know what it could be when i do
Old Mar 26, 2006 | 07:23 PM
Slopoke's Avatar
If you have replaced the oil pressure switch, then its probably a bad connection somewhere.
Check the connector at the switch, then check the pin at the ecu.
Old Mar 27, 2006 | 06:22 AM
lshatch92's Avatar
where is the pin on the ecu? i have 2 diff ecu and it still does it on both of them..
Old Mar 27, 2006 | 10:04 AM
f2m0u5's Avatar
Default Re: (lshatch92)
You'll need to ground the vtec pressure switch wire, or just connect it to the vtec solenoid pin out, btw what kinda car you have? it would help more and also what obd ecu?
mike_h22a1/cd5
Oct 20, 2013 02:15 AM
prime-R
16
Apr 11, 2009 05:33 PM
ToeJam
Apr 3, 2008 06:01 PM
preludefien
Feb 11, 2007 10:43 AM
mister2racer
10
Jul 1, 2005 08:14 PM
