catch can
Old 02-10-2006, 07:35 PM
912's Avatar
Default catch can
i searched post on catch cans, i'm confused a bit when i run line from pcv to catch can do i eliminate the pcv valve or do i simply clamp hose on pcv then run to catch can, see i did lsvtec with b18b1 block with gsr head pcv vave just dangaling no where to put it
Old 02-11-2006, 09:58 AM
R.I.P.
hapexamendios 2.0's Avatar
Default Re: catch can (912)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 912 &raquo;</TD></TR><TR><TD CLASS="quote"> i searched post on catch cans, i'm confused a bit when i run line from pcv to catch can do i eliminate the pcv valve or do i simply clamp hose on pcv then run to catch can, see i did lsvtec with b18b1 block with gsr head pcv vave just dangaling no where to put it</TD></TR></TABLE>yeha, id hate to say it but all of the diagrams ive seen on here didnt make much sense...lets see a super detailed step by step!!
Old 02-11-2006, 03:43 PM
spoink's Avatar
Yes just hook up a line from your PCV to the catch can. This is not exactly a step by step, but you can get the idea. Also dont forget to vent your catch can if it isnt already.
Old 02-11-2006, 07:34 PM
912's Avatar
Default Re: catch can (spoink)
sweet nice set up, that's the catch can i've been lookin at on ebay, looks similar could be wrong ne way. Bro thanks for the info my problem is solved.
VTEC_PRODUCTION
06-02-2009 08:01 PM
4ornia
15
04-04-2007 10:10 AM
912
02-11-2006 02:15 PM
Quick Reply: catch can
