Grinding in third
Old Sep 29, 2002 | 12:03 AM
01gizzer's Avatar
Default Grinding in third
Every time I shift into 3rd m car grinds, I think my clutch is going out but if anyone knows why this is happening please let me know asap I need to fix it.
Old Sep 29, 2002 | 01:25 AM
9d9GSR's Avatar
Default Re: Grinding in third (01gizzer)
it might be the syncros
Old Sep 29, 2002 | 06:26 AM
Regular Series's Avatar
If it's only happening in one gear, it's probably your synchro. Time for a Type-R tranny.
Old Sep 29, 2002 | 06:33 AM
ragejed's Avatar
Default Re: Grinding in third (risingson77)
What they said, my tranny was doing that, i would take it back out to neutral, put the clutch back in and tried 3rd again..still ground. Took 3 trips to acura to replace it
Old Sep 30, 2002 | 02:42 PM
TEGME's Avatar
Where is a good place (online preferably), to look at/buy tranny's (such as the Type-R) My current tranny has 112,000 mi. (95 GSR)Any idea on pricing??
Old Sep 30, 2002 | 02:53 PM
xrtdac
Guest
Posts: n/a
Default Re: Grinding in third (TEGME)
http://www.accuratetrans.com/menu.html
Really great guys to deal with. Set-it up with a local shop or get a tax id number to have it like you are a business. I got my new tranny, 12 month 12K mile warranty for 1100.
Old Sep 30, 2002 | 03:01 PM
MachAF's Avatar
Mines been doing it for a while now too. Its just kinda annoying.
You can have just the syncro is like $300 something. Then labor. I'd just wait till it dies then get a new tranny.
Old Sep 30, 2002 | 03:08 PM
tremor86's Avatar
Default Re: Grinding in third (machaf)
If you dont have the money to fix it now, just do what I do. My third gear grinds and all I do is when I am about to shift into third, I shift about a half inch into fourth then into third. That seems to line the gears up right and it doesnt grind after you do that. Try doing that and if it doesnt work the first time, try going into fourth a little further to see if that work.
Old Sep 30, 2002 | 03:30 PM
piatl7il77's Avatar
yeah it is definately your syncros. cheaper to just get the syncro fixed but then the others may be almost worn as well so you are probly better off getting the whole problem fixed and replacing the whole tranny. other wise youll end up paying more every time another one goes out. also this may be a good time to get a type r with a lsd/
Old Sep 30, 2002 | 04:54 PM
xrtdac
Guest
Posts: n/a
Default Re: Grinding in third (speed23lan)
Type-r tranny not as good for ya if ya are gonan be drag racing and have a forced induction set-up.
PLus. From everything I have seen. a LSD can actually create more stress on your tranny. Yes you may launch better and all that but I would make sure you really need it.
I have an open diff and I pulled 1.9 60" on slicks. Friends I know have the LSD and were only pullin 1.85-1.95 on the same slicks.
[Modified by xrtdac, 5:54 PM 9/30/2002]
Old Sep 30, 2002 | 05:19 PM
piatl7il77's Avatar
Default Re: Grinding in third (xrtdac)
those are very nice 60' times.
Old Sep 30, 2002 | 07:00 PM
TEGME's Avatar
Why would a type r tranny not be as good if you have forced induction? Would I be better off buying another GSR tranny or some other tranny if I am using forced induction??
Old Sep 30, 2002 | 07:09 PM
uNF$@#!'s Avatar
wrong
wrong again
stop giving out false info.
Old Sep 30, 2002 | 07:15 PM
locass316's Avatar
Default Re: Grinding in third (Soup ****)
itr trans is not good for fi because of the very tight gearing
Old Sep 30, 2002 | 11:05 PM
iH8RICERZ's Avatar
welcome to the club! lol
Old Sep 30, 2002 | 11:26 PM
B2FiNiTY's Avatar
Default Re: Grinding in third (locass316)
and what will the tight gearing do?
Old Sep 30, 2002 | 11:36 PM
carl_aka_carlos's Avatar
Default Re: Grinding in third (ExOdy)
i'm sorry, but if I had a turbo car, I would want <close> gear ratios to keep the engine spinning so I'd stay in the boost. turbo cars off boost=turbo lag
Old Oct 1, 2002 | 09:22 AM
project_DC2's Avatar
Old Oct 1, 2002 | 09:41 AM
horizonteg06's Avatar
I got a 92 LS and mine does that too occasionally, its grinds into third only, but I can still put the gear in,...its not like it pushes it out, so you guys say its the sychros...then Im out of luck, I aint got no cash for that, will getting my clutch adjusted help???
thanks for the responses
Old Oct 1, 2002 | 12:52 PM
smdandb2's Avatar
Default Re: Grinding in third (horizonteg06)
My 99LS grinds going into 3rd sometimes. I'm gonna make an appointment with acura soon, get that **** fixed!
Gotta love warranties! My car just barely hit 30000 miles!
Old Oct 1, 2002 | 01:16 PM
nickb20vtec's Avatar
try putting tranny fluid in, it might help, I'm sorry, change the tranny fluid.
Old Oct 1, 2002 | 01:32 PM
Default Re: Grinding in third (nickb20vtec)
Couldn't hurt, plus it's cheap and easy to do.
Old Oct 1, 2002 | 02:19 PM
RedGSR's Avatar
Unbelieveable with all those immature talk about getting an ITR tranny. His GSR is 01, all he needs to do is take it back to the dealer and they will fix it for him.
Old Oct 1, 2002 | 05:34 PM
mickey513's Avatar
Yup, I suggest you change the transmission fluid first. Used Honda MTF or Redline MTF.
Old Oct 1, 2002 | 05:50 PM
Default Re: Grinding in third (RedGSR)
D'oh, I didn't look at his user name ~
But how is encouraging him to get an ITR tranny immature?
