B20Z into 2000 civic questions
Old 08-13-2016, 12:39 PM
Solarflare's Avatar
Default B20Z into 2000 civic questions
Hello everyone, just bought my first Honda, 2000 DX 5spd with a D16y7. I use it as my daily but considering a swap to make it more enjoyable. Thinking about a stock b20z mated with an SI/GSR trans. I know I need axles, I think an ls manifold, and some minor odds and ends for accessories since I want to keep AC/PS. My question is electrical related. Someone keeps telling me I need to swap to OBD1. I'm not so sure I have to since the b20z is OBD2 just like my car. Who's right and what if anything do I need to match the B20 to my harness. Thanks
Old 08-16-2016, 03:26 PM
GDD Member
slomofo's Avatar
Default Re: B20Z into 2000 civic questions
You don't need anything on the electrical side, it's all the same, keep everything electrical from the B20 and use an LS manifold; it'll all plug in unless your B20 came from an automatic, then you'll have extra wires for shift solenoids.
Old 08-16-2016, 04:40 PM
Solarflare's Avatar
That's awesome! Basically B20z, b16 trans, axles, shift linkage. Ecu? What's the easiest way to go about the ECU? Ls ECU chipped or chipped p28?
Old 08-17-2016, 09:19 AM
GDD Member
slomofo's Avatar
Why would you have to chip an ECU? It's a non-vtec engine, just use a stock LS P75 ECU.
Old 08-17-2016, 10:00 AM
Solarflare's Avatar
Didnt know a factory Ls computer could run the B20z with no issue. Thanks I do that then.
93redeghatch
03-24-2010 11:43 AM
layinlowon14s
02-22-2007 10:14 PM
troppop
07-30-2006 04:04 AM
30stones
08-28-2004 08:08 AM
Quick Reply: B20Z into 2000 civic questions
