B20 into EK mount question
Old May 8, 2014 | 12:36 PM
miamihonda's Avatar
Default B20 into EK mount question
Do I need a different post mount / and or bracket (other than the post mount shown & a stock bracket)? Pic attached.
Old May 8, 2014 | 12:56 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: B20 into EK mount question
You just need any 2 post bracket. This is pretty basic swap stuff...
Old May 8, 2014 | 07:23 PM
miamihonda's Avatar
So the stock 2 hole bracket that attaches to the top of the stock mount pictured will work fine with the post mount shown on the motor? The car came missing the bracket so I want to make sure I order the right one.
Old May 8, 2014 | 08:14 PM
MOTORVATIONS's Avatar
The original 2 post/bolt "S" bracket which mounts between the top of the left engine mount and the 2 stud engine bracket is NOT the problem... your issue will be the CRV driver's side engine bracket that is bolted to the engine itself with 3 14mm bolts (two can be seen from the outside and one is hidden by the lower timing cover). This must be changed to the bracket found on the EM1 ('99-00 Civic Si). Then you will be fine.
Old May 8, 2014 | 08:27 PM
SpokaneSpeed's Avatar
100% INCORRECT. Know your facts before giving out false information bud...
Correct. The mount bracket you need is from 99-00 Civic Si. Honda PN# 11910-P30-000
Old May 8, 2014 | 10:26 PM
miamihonda's Avatar
Thanks
Old May 9, 2014 | 08:12 AM
miamihonda's Avatar
I knew I had a post mount laying around from a gsr swap that was in an ek hatch. Does this post mount look correct?
Old May 9, 2014 | 09:35 AM
tony_2018's Avatar
Fish Twig
You only need the bracket that connects them both. See here.
https://honda-tech.com/forums/showthread.php?p=48512011
Old May 9, 2014 | 10:00 AM
kyden's Avatar
the second mount you have won't work either. that is from an integra.
Old May 10, 2014 | 05:14 PM
Cubanstein's Avatar
You need the three hole bracket that bolts on to the ancker mount and the bracket thats is on the block.
Old May 11, 2014 | 03:05 AM
HondaPartsHero's Avatar
Technical Hero
Old May 11, 2014 | 06:15 AM
spAdam's Avatar
Loved
Community Favorite
^Nailed it.
No need to buy anything. I used all my stock mounts on my swap:
Old May 11, 2014 | 10:04 AM
tony_2018's Avatar
Fish Twig
Originally Posted by spAdam
^Nailed it.
These pictures are pointless because they don't show the driver side mount.....
Old May 11, 2014 | 11:46 AM
spAdam's Avatar
Loved
Community Favorite
Correct, didn't have any handy, I was just demonstrating that everything fits fine with stock sohc mounts.
Two post mount:
As it sits:
Old Mar 27, 2021 | 05:10 AM
Ahmad Ossaily's Avatar
Hello fellow honda owners, I got a 1988 civic hatchback with a d15b dual carb, it smocks due to bad piston rings and valve seals, i got a friend who have 1987 accord with a b20a1 engine in it, so my question is can i swap the b20a1 into my civic and does it need fabrication if some sort or is it a straight swap ??
boostontheD
Nov 24, 2012 04:09 PM
BokudenNYC
Apr 28, 2009 09:02 AM
