Which B-series mount bracket is the right choice?
I'm swapping a B20 into my EK, and I've come across 2 brackets that this writeup say's I need:
https://honda-tech.com/forums/hybrid-engine-swaps-18/my-b20-into-ek-parts-list-504321/
"Mounts:
99-00 Civic Si(R) rear mount bracket
94-00 Integra LS/GSR/Type R front transmission mount bracket
96-00 CRV, del-Sol VTEC drivers side front lower engine mount bracket"
I'm not sure which one is the right one:
1: http://cgi.ebay.com/ebaymotors/ws/eB...m=260397872114
or
2: http://cgi.ebay.com/ebaymotors/ws/eB...m=120404373564
Also, I'm having a really hard time tracking down the driver's side front lower engine mount bracket. According to eBay, it doesn't exist. Any ideas where I might track that down. Any help would be greatly appreciated
"Mounts:
or
Re: Which B-series mount bracket is the right choice?
those links are wrong heres everything you need for a B swap in a EK
http://www.hondaautomotiveparts.com/...28DOHC+VTEC%29
#7 , #1 , #10 , part #E 14-1 in the diargram . dont worry about 10 and 1 if you dont plan on running torque mounts , you have to use the T bracket and driver side motor bracket from a 99-00 SI not integra like you do in Eg's
Is this the correct rear mount bracket needed, because I bought it a while ago?
http://cgi.ebay.com/ebaymotors/1999-...3A1|240%3A1318
thats not a rear bracket that the E 14-1 in the diagram , that one of the 2 pieces you need . that bolts to the side of the block on the driver side behind the timing cover only thing you need now is a rear T bracket from a 99-00 Si then the motor can go in .
The 2 pronged bracket on the drivers side by the timing belt cover I have already, so I'm assuming I can keep that. Is that the timing belt mount bracket/ E-14-1? So the only other bracket I NEED is the rear T bracket from the SI? What about the LS/GSR/Type R front transmission mount bracket that the parts list refers to? Would that be #10 on the link you gave me?
****, so I think I bought that for nothing. What about the tranny mount bracket? Thanks a lot for the help. I know I'm a pain in the ***, i just want to do this thing right the first time.
^^^^that is what you sent me in the last ebay listing . so that 1 thing you need , now you need a rear T bracket (#7) from the 99-00 SI . then you can put your motor in . the front tranny mount (you dont need its personal prefrence, but if you do decide to use one thats #10 ) you can just use one from a Si like i am the only two pieces you absolutly need are E-14-1 (only the two prong from a SI is the only that will work) <which you said you already bought. and the second thing you absolutly need is #7 . ...............#10 is optional
REAR T BRACKET #7
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
AND THIS is E-14-1
thats are all you NEED to put the motor in , like i said # 10 is optional . iam running mine without it and iam boosted
REAR T BRACKET #7
AND THIS is E-14-1
