B18c swap no spark
Old 06-01-2013, 11:27 AM
Miguel613ekb18c's Avatar
Default B18c swap no spark
Hi guys just finished my b18c type r swap and I got no spark, I have fuel pressure, I wired up the crank sensor bypass and also the vtec oil pressure switch bypass, I'm using ex civic harness and odb2b p2p ecu my car is 99ek
The engine turns over fine but I checked the splug wires to see it it sparks and nothing,
Pls help
Old 06-01-2013, 05:39 PM
teg97's Avatar
Default Re: B18c swap no spark
Does your distributor wires match plug for plug? Also make sure your igniter is working. Do you have another distributor to check?
Old 06-01-2013, 07:41 PM
My distributor is plug and and play
My vtec fluid I'd good
Ill disassemble my distributor tommarow to check the igniter
Just wondering if there is another bypass I have to do
Old 06-02-2013, 02:43 AM
teg97's Avatar
what bypass is that for ?
Old 06-02-2013, 04:36 AM
The bypass is for crank sensor jdm engines don't come with crank sensor so it has to be bypassed if using odb2 usdm ecu
The igniter is good
Just found out that my distributor plug has 2 extra wires now I gotta rewire from odb2a to odb2b
Old 06-02-2013, 04:44 AM
teg97's Avatar
ahh ok. Yea I will be bypassing the crank sensor as well once I get my motor
hope those 2 wires fix your problem
Old 06-09-2013, 08:49 PM
Calhonack's Avatar
Didn't the 99-2000 have a immobilizer? Or just some of the 2k Ecu's ? Just a thought
Jeremy Harris
21
05-02-2016 10:58 AM
samedure
03-22-2016 12:44 PM
ej8fosho
10-30-2008 09:29 PM
chet
04-19-2003 12:07 PM
gigantor
03-27-2003 01:11 PM
Quick Reply: B18c swap no spark
